thundermax maps and injector size
Old Feb 29, 2008 | 07:48 PM
wydopn231's Avatar
wydopn231
Default thundermax maps and injector size
Im looking for info on maps and injector for currant hop up.I have 95 ci tc.Andrews 59g cams,factory heads with 194/1.60 valves fully ports and shaved heads,compression is right at 11:1,throttle body has been bored out to 534 mm(if doing this stop at 52 or 53),doherty A, C. and power vents,thunder header 2 into 1.Ive found cpl maps close but would like to zero in on cams and throttle body and compression lil closer to make the learning curve easier on comp.
Old Mar 1, 2008 | 08:40 AM
C-Cat's Avatar
C-Cat
Default RE: thundermax maps and injector size
i'm running bored out stock throttle body and used a map for my injectors and stock throttle body and it works fine. i would find your injector size and injector and not worry about it being bored out. as far as cam and compression get as close as you can. ex. i'm running a woods 7h cam my map (319) is for a red shift 577, it seems to run good breaking in some (not running #'s yet) on my friends dyno. i may have to alter the timing later on if i have any detonation issues, as i'm @ 10:4 to 1 compression. the dyno guy is impressed with the t-max, even though he was sceptical at first.
Old Mar 1, 2008 | 10:12 AM
ToBeFrank's Avatar
ToBeFrank
All of the maps with the 1.9/1.63 ported heads, red shift cams, and high compression pistons have the exact same timing so really it comes down to getting your throttle body and injector size as close as possible. At 11:1, you may end up having to back the timing off some.
Old Mar 1, 2008 | 06:11 PM
wydopn231's Avatar
wydopn231
thinks guys In hoping the bigger cam help with detonation.I know Im pushing it but do you expect from guy who drove blown alchol dragster and crew chiefed alchol funny car.If its not on the line your just scared right.Any Starr Rider funny car fans out there.Hey spent to much money and lost to much hair not to get free plug in when can.
target64
Jan 31, 2013 08:08 PM
naddo72
Aug 24, 2011 07:18 AM
donovann2o
Dec 15, 2010 06:49 PM
97badfatboy
Nov 27, 2010 05:47 PM
cts1950
Nov 28, 2008 07:50 AM
