fuel in my engine
Old Mar 2, 2008 | 10:12 AM
guitbike's Avatar
guitbike
6th Gear
Default fuel in my engine
i did my oil change yesterday and just when i was done the phone rang,i started talking on the phone for a while then ihad a snack,when i went back to the garagethere was a pool of fuel aroundmy bike,it was coming out from the exhaust,i started investigating,that's when i realized i had not closed the petcock and on top of that the choke was pulled all the way,itook out the spark plugs and one of the cylinder was completely filled with fuel,in the othercylinder the fuel came out from the exhaust,i used an antifreeze tester pump to empty all i couldi then blewsome compressed air in the cylinders,i cleaned the mess sorounding my bikeleft the spark plugs out,i opened a window to ventilate the garage and i called it a night,so here i am the day after the disaster and here's my plan,i have one of those cors contaminated oil removal fitting,i took out my oil filter and it looks dry so i don't think oil went down there since i didn't start the bike afterwards,so i reinstalled the cors fitting on the bike and my plan is to crank the engine with no spark plugs, little by little to remove a pint or two by the cors fitting,since my oil tank is filled with fresh oil it will push out the fuel filled oil out the crankcase,what you guys think ? i'm a newbee it's my first harley and this was my first oil change.thanks
Old Mar 2, 2008 | 11:08 AM
rkadair's Avatar
rkadair
Default RE: fuel in my engine
sounds like you have a bad float or needle seat in your carb time for rebuild should not be pouring gas out like that
doakley2
EVO
18
Nov 28, 2019 07:47 AM
Camel56
Jun 2, 2019 08:07 PM
chekster88
Apr 15, 2016 01:23 PM
cchawg
May 29, 2013 09:40 AM
Kisse87
Mar 31, 2010 07:04 AM
