Spark plug heat
Old Mar 6, 2005 | 05:30 PM
igniter's Avatar
igniter
Default Spark plug heat
A wrench said to change spark plugs heat range to cooler to help reduce pinging when engine gets hot on an RK. Changed ranges and it seemed to help. It didn't cure it but made a noticeable difference. My question is what happened? Does the heat range make it feel richer, leaner, etc.? What is the difference in the two plugs, type of metal used in electrode, or what?[sm=dontgetit.gif]
Old Mar 6, 2005 | 07:04 PM
investorsc's Avatar
investorsc
Default RE: Spark plug heat
Increases in firing-end temperature are proportional to engine speed, load, or in the case of air cooled temperatire- thermal load. When traveling at a consistent high rate of speed, carrying/pushing very heavy loads, or operating air cooled engines with minimal cooling for extended periods- a colder heat range spark plug should be installed. It keeps the firing end temps down and help prevent pre-ignition,detonation or engine damage!
BRUCE
Old Mar 6, 2005 | 07:32 PM
pococj's Avatar
pococj
ORIGINAL: igniter
Look at the 2 plugs side-by-side. The colder plug will have less of its center electrode extending past the threaded portion.
nosinjcted
May 19, 2022 04:26 PM
TORQUEY
May 31, 2011 11:12 AM
pirate4hire
Oct 15, 2007 08:49 AM
DCRANER
Jun 6, 2007 09:32 AM
Ironhead
May 11, 2006 07:25 AM
