need some help...please
i have an '03 hugger with a 1200 upgrade that utilized the stock heads. this was done about 1500 miles ago. recently i have been having starting issues when warm. occasionaly when i stop for gas and go to start all i get is coughing out the carb, backfiring, and flames out the pipes. once i let it cool down for about half an hour or so, it will start fine. also sometimes when i start my bike it will run poorly after warm up, it will barely idle, and when i hit the throttle i get a cakle sound out of the pipes instead of its sweet rumble.
any help would be great, thank you all!
this may be the blind leading the blind but one thing ya might check is the idle mixture screw on the carb. the link below has some info on it. if thats not it then you need to seek professional help
http://www.nightrider.com/biketech/carbadjust.htm
and I'd like to apologize for the forum, 34 hits and not a single reply in 2 days, brotherhood, yeah right
i appreciate the input.
as far as for the others, i wont hold it against them, **** happens.
thanks again[sm=deal.gif]
