I am currently running Thundermax autotune, screaming eagle slip-ons, D&\\;D true duals, and a Zippers air cleaner. My question is: Can \\;I replace the slip-ons with stock and the Auto tune will recognize this and adjust as needed?
Thanks
It works both ways, because I tried.....
Installed a set of Rinehart mufflers \\;on my FXDC07 Dyna and after about 100 miles of riding and selftuning with the TMax \\;I had no option but to return to original because my neighbours hens layed no more eggs and the cows run out of milk (I live in the countryside as you might have guessed).
The bike run fine, but would not pull as hard as before over 4K which is only natural.....[:@] \\;so I went for a set of Screamin'Eagles (the new ones with an extra \\;hole done on the flat end of the baffle 3/4" burned out with an electrode!). RESULT: Plenty noise without going crazy, bottom-medium-high up and power curve smooth all the way and that in less than a week and without fiddling with the map .
I'm trying to do the same with my 110 CVO Springer 08, but not as simple\\; get popping and also need to use my "surgical" welding machine to open a bigger hole in the baffle because over 5K my power curve flattens out [:'(]
Anyway the fact is that TMax will adapt itself to the new environment all by itself.
BR,
Spanish Flyer
