Compression ? Need to figure static close guess would help
Hi I am building a 95 inch twin cam motor right now and here is where I am at. And if I should have compression releases put in these heads. I am also think to change cam choice to the new TW54 cam it seems to turn on sooner 2200 instead of 2600 like the tw55 I am going to using now. This is also going in my bagger FLHTCI (FLHX CLone) I was told this cam I am using now likes about 10 to 1.
SBC ported Head chambers set to 84CC
JE 10.25 forged piston kit
Andrews Tw55 cam
Jims Hydrosolid lifters
Crane ADj. Pushrods
Jims Gasket set .036 head gasket, how much \\;change when you use .030 head gasket instead
Any Help Please
TIA
RE: Compression ? Need to figure static close guess would help
Thanks for the tip that helps out. I really need to dial in on the for head gasket thickness. It look like I will need james .046 head gaskets or my compression with 10.25 pistons will get a bit to high. I always use good gas but I really did not want to get to much over 10 to 1 and this should get me at 10.07 to \\;1.
would \\;anybody know now @10.07 \\;to 1 should I install compression releases? \\;
