ADJUSTABLE PUSH RODS
Old Jul 6, 2008 | 01:12 AM
JMN68's Avatar
JMN68
Default ADJUSTABLE PUSH RODS
I will be changing out the the stock cam chain drive&nbsp\\;to gear drive cam on my 06' streetglide.&nbsp\\; This will be my first shot at this.&nbsp\\; I am not familiar with the steps leading up to pulling the cam.&nbsp\\;&nbsp\\;What are the steps to set the cylinder in the correct position&nbsp\\;before cutting the stock push rod with bolt cutters?&nbsp\\; Then after&nbsp\\;the cams are in the case,&nbsp\\;what are the steps&nbsp\\;to adjust the push rods to proper length?&nbsp\\;Thanks in advance.
&nbsp\\;
Joe
Old Jul 6, 2008 | 12:29 PM
Harleypingman's Avatar
Harleypingman
Default RE: ADJUSTABLE PUSH RODS
Joe, do you have the HD Service Manual for your bike?
Old Jul 6, 2008 | 07:29 PM
schmeg's Avatar
schmeg
Ditto on the manual.
Old Jul 6, 2008 | 07:41 PM
2005UltraNC's Avatar
2005UltraNC
Maybe this link will help: http://harleyhog.co.uk/1550/bbonline.htm
Old Jul 6, 2008 | 09:09 PM
JMN68's Avatar
JMN68
I do have the manual but pictures are even better.&nbsp\\; Thanks 2005UltraNC for the link.&nbsp\\; I will be doing the cam change change this week.
&nbsp\\;
Joe
Old Jul 6, 2008 | 09:38 PM
deadeye1340?'s Avatar
deadeye1340?
One cam will have to be pressed out of the cam plate, this is the time to swap the bearing out too.&nbsp\\; Swap out all cam bearings for that matter.&nbsp\\; With&nbsp\\;stock pushrods, clip them in what ever postion the motor is in, it doesn't matter.&nbsp\\; When installing the adjustable pushrods, it is VERY important to follow the directions that come with the pushrods, since they are specific to the thread pitch for those very pushrods.&nbsp\\; The directions along with your manual will tell you how to position the valve train to get the pushrod adjustment right.
Bryan3091
Engine Mechanical Topics
Mar 12, 2019 03:36 PM
Snowmaster113
Jan 22, 2019 09:01 AM
ntg433
Oct 17, 2013 01:24 PM
Danakelble
Feb 28, 2012 11:34 AM
daveMD2011
Aug 4, 2011 10:45 AM
