baffle removal help needed
Old Jul 17, 2008 | 12:56 PM
Larryc5079's Avatar
Larryc5079
Default baffle removal help needed
Last night I helped a friend remove, well try to remove, the baffles from the V&amp\\;H exhaust.&nbsp\\; I have replaced mine and it was very easy.&nbsp\\; These wouldn't budge.&nbsp\\; Tried letting the motor run for about 10 minutes to heat the exhaust up and that helped a little.&nbsp\\; Also tried WD-40 with little success.&nbsp\\; Come to find out, he had used packing tape to hold the fiberglass in place on the baffles when he installed them!!!!!&nbsp\\; I am pretty sure that the tape has melted and gummed up around the baffles!!!!&nbsp\\; Any ideas on how to remove them????&nbsp\\; Anything to dissolve the tape??&nbsp\\; Any special tools to help remove??&nbsp\\; Any help is greatly appreciated.
&nbsp\\;
Thanks,
Larry
Old Jul 18, 2008 | 10:11 AM
MCSarge's Avatar
MCSarge
Default RE: baffle removal help needed
I would go to the next joint up stream of the baffles and take it off and drive the baffles out from that end and pull on the back at the same time.
A Whole lotta Rosey
Jul 27, 2013 08:57 PM
Keith_71
Aug 7, 2011 11:31 PM
inspector126
Aug 8, 2010 10:11 AM
klaybus
Sep 21, 2008 10:22 PM
Slamedride
Sep 8, 2006 09:12 PM
