Fuel smell in oil
Old Jul 31, 2008 | 07:15 PM
WARG's Avatar
WARG
Default Fuel smell in oil
On a recent oil change I noticed a fuel smell in my oil.&nbsp\\;\\\\\\; My last two tanks I got 37 mpg, mix of city and highway riding. Am I running too rich?&nbsp\\;\\\\\\; NO black smoke, no burning oil.&nbsp\\; I took some short trips this winter which didn't get the bike up to operating temp, maybe there was unburned fuel in the cylinders that leaked into the crank case. I have changed oil since, but there was still about 1/2 quart of the old in the bike.&nbsp\\; Any ideas?&nbsp\\;
Old Aug 1, 2008 | 07:07 AM
mulch63's Avatar
mulch63
Default RE: Fuel smell in oil
I assume your bike is carb....correct. I have a S&amp\\;\\\\\\;S on one of my bikes I thought the same thing about fuel in oil. Mine was the carb seems to hold a bit more fuel in the bowl and after the bike sat a bit evaporated fuel fumes leached over into the tank and gave off the odor of fuel in oil. Run the bike good get it heated up and then when you come back pull the stick and smell in the tank and see if you smell fuel.
&nbsp\\;\\\\\\;
If still worried change oil again and pull the oil line and drain out the last 1/2 quart. I can't remember the overflow set up on the stock carb. But ususally fuel will come out the overflow before going into the cylinders when sitting.
&nbsp\\;\\\\\\;
jim
Old Aug 1, 2008 | 08:54 PM
WARG's Avatar
WARG
Actually it fuel injected.&nbsp\\; Someone said that by taking short trips unburned fuel could leak by the pistons and contaminate the oil in the crank case, but was also told that oil will not negatively affect the viscosity of synthetic oil.&nbsp\\; My mpg has only been about 37 my last two tanks.
Engine Mechanical Topics
29
Sep 11, 2014 11:20 PM
cchawg
May 29, 2013 09:40 AM
Kisse87
Mar 31, 2010 07:04 AM
crazytrain69
Nov 23, 2008 10:17 AM
WARG
Oil Archive (no new posts)
Feb 27, 2008 03:19 AM
