Ordering Jets???
Old Mar 17, 2006 | 02:42 AM
needadyna's Avatar
needadyna
Default Ordering Jets???
Anyone know a good place online to order jets. I want a #52 and #55 slow jet.
J&P doesn't carry them
Old Mar 17, 2006 | 03:05 AM
vernh59's Avatar
vernh59
Default RE: Ordering Jets???
What mods do you have on your ride? Thats some BIG jets!!!!!!!!!
Old Mar 17, 2006 | 04:13 PM
needadyna's Avatar
needadyna
I've got V&H BigShots Staggered, and a "Hypercharger". I don't have anything else, just got that popping when I decelerate.
I bumped my slow jet up to a #50 and my main jet up to a #195. I've also got 2 washers under my needle. I tried different settings on my idle mixture.....doesn't seem to make much difference. Plugs look better, just thinking I might still be a little on the lean side. Thought I'd try a #52 and see if that helped. The jets aren't much, I figured if I was gonna get a #52, I might as well get a 54.
Any suggestions???
Thanks
Old Mar 17, 2006 | 04:51 PM
rm4040's Avatar
rm4040
Is the popping out of the carb or exhaust? If it is the exhaust and not the carb, I don't think you are running lean. You may want to check for a leak in your exhaust pipe. Running over a 48 is to much in my opinion.
Old Mar 18, 2006 | 02:35 AM
needadyna's Avatar
needadyna
Sounds like it's coming out the exhaust.... I guess I should check for manifold leak.
Any other suggestions..
Thanks
Old Mar 18, 2006 | 03:11 AM
vernh59's Avatar
vernh59
I think some popping is probably normal. The muffled kinda pop. It shouldn't sound like you are at a gun fight. Check for leaks at the manifold and the exhaust clamps. Vibrations could cause the clamps to loosen and Harleys vibrate- who knew? I run a 48 pilot jet with the screw at about 2 turns. Seems to run fine. My sig lists mods on my RK.[&:]
Am4wag
Jun 21, 2013 06:16 PM
Punisherdave
Jul 19, 2012 07:14 PM
SBW Cycles
Nov 16, 2011 02:08 PM
64 stroker
Apr 4, 2011 11:38 AM
jackofhearts
Mar 1, 2008 05:24 PM
