Base Gaskets
Old Dec 9, 2008 | 08:59 PM
rbabos's Avatar
rbabos
Default Base Gaskets
I will eventually be going 113. I have this mental block about going back to the stone age with base gaskets as opposed to O rings. Are these base gaskets leak proof or do they seap after a while. Almost convinced myself they are fine because if a head gasket works the base should as well, but still read about the odd one that leaks.
Ron
Old Dec 10, 2008 | 05:17 PM
Old Gunny's Avatar
Old Gunny
My cylenders from Axtell came with a base gasket. Cometic steel for, I believe, an Evo. The instructions said to use them and the "O" ring both. Called and asked (annal) and they said use both.
Thing you will have to watch is Deck Height. But it will only be about 0.010", or a little more.
I would use both, if you can, for a Harley 113 or any if I had it down that far. Insurance.
Will very, very slightly raise the deck which could help valve clearances. I would be sure and use a Cometic or James 0.030 in head gasket.
Old Dec 10, 2008 | 07:49 PM
Dalton's Avatar
Dalton
Used the HD MLS base gaskets on my 120. HD instructions were very clear - do not use the o-rings on the cylinder or oil returns. I followed the instructions and have 18k on the build with no leaks.
Old Dec 10, 2008 | 08:35 PM
TXCHOP's Avatar
TXCHOP
Ran a full season already on my 117. No sign of any leakage or seepage. These twin cam cases are much better than the EVO's were.
Hillside Cycle does a ton of builds with Axtell cyls, give Scott a call.
Old Dec 11, 2008 | 03:19 PM
rbabos's Avatar
rbabos
Thanks for the info. I think I can get use to the idea.
Ron
hdHuck
EVO
Aug 16, 2014 06:20 AM
dirtbag1
EVO
Oct 25, 2012 06:03 PM
straydog13
Ironhead
Aug 19, 2008 09:44 AM
grippper
Jul 10, 2008 10:48 PM
bigstevex4
Jun 4, 2008 03:11 PM
