Starting Problem
Old Mar 10, 2009 | 07:36 PM
Figstr's Avatar
Figstr
Default Starting Problem
About 3 weeks ago I put on a 2" tank lift kit. Since then the bike's been hard to start once in a while. The starter will turn over and then it sounds like the engine "skips." When I let off the starter button I hear a sound like a blast of air for a second or two. I hit the starter button again and she starts up fine. It doesn't always do this but seems to do it more often when the motor is hot. I also get the smell of fuel after the hiss as though I flooded a carb, yet the bike is FI. Any thoughts as to what is causing this?
Old Mar 10, 2009 | 08:00 PM
Old Gunny's Avatar
Old Gunny
I think the FI cranking fuel is too rich. What ever you use, SERT, PC, etc, cut the cranking fuel.
Mine made those same sounds and hard starting especially when hot. I nickeled and dimes the thing (small adjustments) and then made a -10 on all cranking fuel. Fired right up. Can always fine tune later.
Old Mar 10, 2009 | 09:12 PM
rambobob's Avatar
rambobob
Mine use to do the same thing. Now I have compression releases on my 103 bb. So far no issues. I read alot about the strator being weak on the 07"s.????
Old Mar 15, 2009 | 03:21 PM
Figstr's Avatar
Figstr
I have a fuel pak with V&H staggard pipes. I had these put on before I picked it up 2 years ago from the dealer. The problem didn't start until after I put on the tank lift kit. Would a lift kit cause me to have these problems and force me to recalibrate the fuel pak? Doesn't make sense to me.
JD_HOG
Jul 2, 2019 11:49 AM
1911NT
Jul 9, 2016 04:30 PM
Pgh-mike
EVO
15
Jun 5, 2016 07:42 AM
Nightcruiser
Jan 10, 2015 11:26 PM
rrdugas
Dec 19, 2007 10:44 AM
