'07 FXDB Starting issue
Old Jul 2, 2019 | 09:24 AM
JD_HOG's Avatar
JD_HOG
1st Gear
Default '07 FXDB Starting issue
So for a few weeks now I've experienced intermittent starting issues on my 2007 FXDB... Starter rolls and acts like no fuel is present? I believe I narrowed it down to the check valve in the quick disconnect under the tank?? It is not leaking at all with the fuel line connected but if I disconnect the line the fuel trickles out so pretty sure its not just the o rings. But what's a little confusing is if I let her sit for a bit It'll fire fine and run perfectly which leads me to believe I'm on the right track and it's not my starter relay. Anyone else experience similar issues? Any leads on where I should start? Thanks in advance y'all
Old Jul 2, 2019 | 11:49 AM
nevil's Avatar
nevil
Look for leaks in the internal fuel line.
John Mayo
Sep 3, 2018 06:32 AM
1911NT
Jul 9, 2016 04:30 PM
Pgh-mike
EVO
15
Jun 5, 2016 07:42 AM
Nightcruiser
Jan 10, 2015 11:26 PM
rabidd
Exhaust System Topics
Feb 28, 2011 11:27 AM
