back fire through throttle body
Old May 28, 2009 | 10:07 AM
1roadking's Avatar
1roadking
Default back fire through throttle body
I have a 2005 roadking classic with EFI. I put vh big shots on it and a zippers thundermax. It runs awsome but it will occassionally skip when rolling the throttle with the clutch pulled at a stop or during downshifts. It is only off idle and runs great otherwise. It sounds like a puff of air goes through the throttle body. It never stalls, but it feels like it is going to and has been an issue when pulling away in a turn because it will momentarily loose power. It has done this since new. I originally had a stage 1 screeming eagle mufflers and down load. It seems better with the thundermax. Again, the bike riuns great otherwise. Any ideas. I am new to the forum and really appreciate any ideas. Thank you.
Old May 28, 2009 | 03:04 PM
Old Gunny's Avatar
Old Gunny
Sounds like the Accelerator Enrichment needs to be boosted a point or two.
A SERT or TTS Mastuner will do that. On of the others might. Someone will know.
Old May 28, 2009 | 03:33 PM
the blob's Avatar
the blob
id ck for intake seal leak. or its lean in the off throttle range.
Old May 28, 2009 | 03:53 PM
1roadking's Avatar
1roadking
A leak in the intake was the guess by my mechanic as well. Is that the common consensus. Even with the thundermax, it is a little surgy down low. Would that be indicative of a intake leak as well? Thanks for the help.
67Shuv
Jun 22, 2019 11:16 AM
LedBoots
Aug 29, 2014 05:33 PM
Kbore
Apr 12, 2009 11:43 AM
nitro17
Jul 15, 2008 01:56 AM
Z_Stingray
May 27, 2008 07:34 PM
