Miss/Backfire Problem
Old May 30, 2006 | 02:22 AM
JonRGuitar's Avatar
JonRGuitar
2nd Gear
Default Miss/Backfire Problem
I have a 2004 carbureted softail with a Stage 1 system, 4200 miles with a miss/backfire after warm-up. This backfire is intermittent and loud. I have checked jetting, checked for intake manifold leaks, replaced exhaust gaskets, plugs and intake manifold seals. The backfire reminds me of a quick flick of the kill switch. Short hesitation then backfires. I have cleaned the ignition switch and checked the kill switch itself. I cannot seem to get rid of this backfire. Any ideas guys? Also, any freelance HD mechanics in the Las Vegas area? Thanks!
Old May 31, 2006 | 06:03 PM
TrollFromDownBelow's Avatar
TrollFromDownBelow
6th Gear
Default RE: Miss/Backfire Problem
Did you ever figure this out? I've got a similar problem described about 10 posts above -
Old May 31, 2006 | 07:29 PM
JonRGuitar's Avatar
JonRGuitar
2nd Gear
Troll,
No! This is driving me crazy! Does yours backfire after warmup with some throttle input? Is it every now and then or is it more frequent?
Old May 31, 2006 | 07:59 PM
TrollFromDownBelow
6th Gear
The stage 1 kit helped, but didn't cure it. It occurs after warm up like yours, but seems to be random - I can drive for several miles and it's fine, then it might do it a couple of times. Mine also seems to happen at within a very narrow rpm range... I'm guessing 2k (whatever 40mph in 4th works out to be). If I drive with the choke partially on it doesn't happen.
Old May 31, 2006 | 10:24 PM
JonRGuitar's Avatar
JonRGuitar
2nd Gear
It sure sounds like the same problem! I have not ridden with the choke partially out but I don't think mine is fuel related. I have gone through the carb with a fine-tooth comb! What is your backfire like? Does it hessitate then backfire? Did you replace your plug wires?
Is there any Master Mechanics here that can help Troll and I with this?
Old May 31, 2006 | 10:29 PM
tripl8's Avatar
tripl8
What carb are you running?..its a fuel adjustment setting ..most likely, Idle Adjustment.
Old May 31, 2006 | 10:48 PM
JonRGuitar's Avatar
JonRGuitar
2nd Gear
Tripl8,
Stock carb and I have gone through it with jets, needle and everything else I can think of! I have done the plug check and I seem to be right on the money. I have replaced the intake manifold seals and carb boot. I do not have an intake leak. I have the air mixture screw out 2 turns right now and have tried many settings. Like Troll, it is intermittant and can go for miles before it backfires again. Sometimes with little throttle movement, sometimes with none.
What gives guys?
Old May 31, 2006 | 10:59 PM
tripl8's Avatar
tripl8
Then my moneys on an intermittant ignition short...findng it might be a bitch tho.
Old Jun 1, 2006 | 12:11 AM
JonRGuitar's Avatar
JonRGuitar
2nd Gear
I am thinking the same thing too. I cleaned the ignition switch and blew out the kill button but it still backfires! Damn!
Old Jun 1, 2006 | 12:19 AM
TrollFromDownBelow
6th Gear
Other than a stage 1 kit, my carb is stock as well. In my case I'm leaning towards an air/fuel mixture problem rather than spark/ignition because I don't have any problems if I run with the choke on 1/3. Anyone know how many rpms the engine is turning at 40mph in 4th gear? More importantly, which jet is most important for the air/fuel mixture at this rpm/load/throttle position (cruising steady on flat road)?
