dynojet setup
Old Jun 17, 2006 | 06:09 PM
vailtl's Avatar
vailtl
Default dynojet setup
I realize that this has been gone over time and time again but.
What is the proper setup for dynojet on the 88tc.
I pulled the carb installed their needle, put the clip on the 4th grove down,
installed their emulsion tube and their 180 mainjet, drilled out the plug,
drilled out vaccum hole.
Now in the picture they show the three washers, shims all lined up looking
as they go ontop of the clip, the small end of needle.
That does not make sense to me it seems they should go under the clip
to aid in raising the needle. what do you people think?
I also left the stock # 45 slow jet in the carb.
The bike runs great but the sparkplugs are really light.
This is on a year 2000 wideglide
My mpg is around 32-35
I would like better any sugestions?
Old Jun 19, 2006 | 10:00 AM
murphdog's Avatar
murphdog
Default RE: dynojet setup
The washers go on top of the needle clip as a starting point. They don't do anything on top of the clip, but you can use one or more of them under the clip to fine tune the needle if you want. If you put them all under the needle with the clip in the 4th groove, your extremely poor mpg will go down even more.
If you're looking for suggestions, mine would be to get rid of the kit and buy an 88 Sportster needle 27094-88. That's what I did (95" 2003 wideglide) and mpg on my last tank was 49.75. The Dynojet kit is notorious for poor mpg.
Here's a good article on what works: http://americanrider.com/output.cfm?id=1021951
0maha
EVO
44
Aug 25, 2015 12:10 PM
Quadancer
Carburetor Related
24
Apr 20, 2012 12:55 PM
CURTYS06FLHX
Jun 4, 2010 08:53 PM
virtualmike13
Oct 26, 2007 10:45 AM
vailtl
Jun 28, 2006 10:44 AM
