Compression test specs
Old Oct 8, 2009 | 07:51 PM
Longbeards Ghost's Avatar
Longbeards Ghost
2nd Gear
Default Compression test specs
Was wondering if anyone has the best, and minimum acceptable compression specs for a 94 Ultra. (80" Evo) Shows 90 psi both cylinders @90K miles.
Old Oct 8, 2009 | 08:08 PM
splitting_lanes's Avatar
splitting_lanes
90 psi is low, but i'm wondering if your gauge is working right. can you check it with a different gauge, or try the gauge on your car?
Your front and rear are very close to the same, which is very good. if it still runs good and it really is that low (the gauge is accurate), then don't sweat it too much.
I just checked my front and rear cyls at 49,000 miles and they were both at 182psi, higher than i expected.
Old Oct 8, 2009 | 09:39 PM
chipdavey's Avatar
chipdavey
Factory specs on BT Evo is only like 80 psi, make sure the throttle is wide open when checking compression, gotta let the air in
Old Oct 23, 2009 | 11:26 PM
Longbeards Ghost
2nd Gear
I re-tested, and they both show about 120lbs. +/- 1 lb. that seems more like it.Thanks.
Old Mar 25, 2013 | 09:02 PM
smitty0629's Avatar
smitty0629
3rd Gear
got a 59 pan that I'm working on, its a bear to start, got it going twice with a shot of starting fluid, went thru the M carb and seen nothing out of whack, checked compression and have 90 in rear and 60 in front, thinking I might of figure my troubles ???????
Old Mar 27, 2013 | 04:33 PM
46u's Avatar
46u
A leak down test will show things a compression tester will not. Until I bought my 02 ultra in 01 I never had a electric starter on a Harley since 1971. never had a problem cranking any of them. No such thing as a hard starting Harley just one out of tune or needs engine work. LOL good luck.
Fat11Lo
Engine Mechanical Topics
16
Dec 1, 2017 08:25 PM
decencyxdefied
Nov 8, 2015 09:07 AM
07bobber
Jan 17, 2014 01:12 PM
sharkharleyrider
Oil Archive (no new posts)
Sep 7, 2012 11:02 PM
Ride my Seesaw
May 9, 2010 05:21 PM
