Gas Leak need Help!
Old Oct 29, 2009 | 03:34 PM
HDZellm's Avatar
HDZellm
Stage II
Default Gas Leak need Help!
I have purchased a 2001 sportster 1200 xlc last year, with a custom job 2004 4.5 gallon gas tank put on it. This year I started noticing a gas leak on the left side of my tank by the petcock. I had found the leak in the tank right around the petcock had it welded, this fixed the problem for about a week. Now When I start it up for a while I get gas coming out the overflow tube and small spots on the ground on the left side but no visable drips coming from anywhere. Any help????? I also have replaced the gas cap, and it is not too full.
Old Oct 29, 2009 | 04:17 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Sounds like the float is not closing completely... hence the overflow tube spitting fuel...
Drop the bowl and clean it out...
Old Oct 29, 2009 | 04:32 PM
Nightking's Avatar
Nightking
Exactly, you have an overflow tube running from the carb and it hangs down at frame level on the underside. Sounds like you just have some trash in the needle valve.Now, if all of that is clean, then you may have a pressure build up in the tank from the gas fumes. A vented gas cap does not mean it vents the tank. It only vents one direction (inward flow). But, if it just now started doing this that most likely is not the prob.
Old Oct 29, 2009 | 06:33 PM
HDZellm's Avatar
HDZellm
Stage II
Thanks, I also just started noticing moisture again around the petcock and tube coming off from it. Would that still be the same problem? And so if my gas tank was still leaking that would not cause this?
Pfarley1
Aug 14, 2018 04:39 PM
zeprulz
Carburetor Related
May 19, 2014 05:13 PM
raygk9
Dec 8, 2011 12:18 PM
tony2nuts
Jun 15, 2005 12:49 AM
tony2nuts
Jun 15, 2005 12:36 AM
