HSR 42 Poor Fuel Economy
Old Nov 10, 2009 | 10:21 PM
Tommy711's Avatar
Tommy711
Stage III
Default HSR 42 Poor Fuel Economy
Okay so heres the dueal. I just recently put a new mikuni hsr 42 on my 05 dyna superglide sport. I run an 88 CI engine and have v&H big radius pipes, I also have a stage 1 ignition kit in there as well. The problem Im having is Im only gettting like 31-33 MPG. Which is horrible! And thats if Im lucky. the carb is currently set at its stock setting of 25 pilot, 165 main, and the stock jet needle that it comes with. My question is what jet configuration should I be running on my 88 CI? Anything would help out guys. I appreciate it.
Old Nov 11, 2009 | 07:09 AM
murphdog's Avatar
murphdog
The 25 pilot jet is usually too rich, try a 20 or even a 17.5.
The standard accel pump nozzle is a 70, try a 50.
Stock needle is a 97, try a 98 (leaner) with clip in the middle.
Stock main jet is a 160, most folks use a 165.
You should be able to pick up at least 10 mpg.
Old Nov 11, 2009 | 11:26 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Those pipes could be "over exhausting," and causing you to pull on the loudstick harder that you would have to, with a different pipe.
Generally those slide carbs show good mpg.
Scott
Old Nov 11, 2009 | 04:30 PM
grbrown's Avatar
grbrown
A good choice of carb, but IMHO setting carbs up is a black art. You can either spend time buying and fitting different parts and possibly getting it better, or visit a tuning shop who knows their Mikunis and will sort it out in a blink. Your call on sorting it soon, or sometime!
Old Nov 11, 2009 | 04:59 PM
moosh's Avatar
moosh
Thumbs up
exactly, drop your pilot (17-20)- 98 needle (middle of clip) main could be right on at stock 160 but experiment I do use a 165...
Old Jul 25, 2010 | 10:20 AM
Tommy711's Avatar
Tommy711
Stage III
Thanks for your help guys. Sorry I didn't reply sooner. I'm currently deployed now. I appreciate your help.
Bradley Jones
Carburetor Related
16
Apr 22, 2015 05:08 PM
ralix13
Mar 6, 2015 08:34 AM
Pimonberg
Carburetor Related
Aug 27, 2014 06:57 PM
Chopster1200
Oct 27, 2009 02:12 PM
Softbutt
Feb 2, 2006 12:32 AM
