Iron 883 conversion
Old Jan 31, 2010 | 12:08 AM
Ironman507's Avatar
Ironman507
Stage II
Default Iron 883 conversion
Hi all, I'm about to take delivery of my first Harley (Iron 883) after years of zipping about on Superbikes (had to sell my Ducati 916 when I emigrated to Australia). I've got a list as long as my arm of modifications that I want to get done on my new Iron but my ultimate goal is to get as much power/torque out of the Iron as possible.
Initially I am just going to fit V&H short shots, heavy breather filter and power commander but I intend to get it converted to 1200cc and fit gas-flowed heads/racey cams etc.
I would appreciate any constructive advice regarding performance mods to a 1200 conversion. Thanks in advance.
Old Jan 31, 2010 | 05:27 AM
grbrown's Avatar
grbrown
Welcome to HDF from the UK! You're asking how long a piece of string is! While many of us here on HDF are looking out on snow and frost and you are probably mid-summer you would be well off taking delivery of your new bike and getting used to it, while browsing HDF to get a measure of your new beast.
It is also worth pointing out that most discussion here on tuning actually takes place in the Sportster forum, where you will probably pick up more than in here. The forum is well structured, but the users ain't!
If you plan to have your own heads gas-flowed you will obviously need access to a suitable tuner. If you know one my advice is to make friends with him and consult on all the other things. There are Harley owners who do everything themselves, mixing and trying to match parts from all over, while some tuners know their Harleys and can offer a well-tried recipe. That is the shortest route to a successful result!
Having owned Harleys since the 70s and seen the majority of modified ones running less than pefectly I now use specialists who know their way around. Better results first time and skilled backup if needed.
Old Jan 31, 2010 | 06:54 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Iron XL's were 61" engines, not 55"s(883).
If it is and Ironhead, then a 4 5/8" stroker kit is the way on those, along with head mods, Andrews cams of several different flavors, DTT ignition,
S&S carb. Those are very quick set up like that.
IF, it is a 883, then bore to 1200, Andrews 8 cams, headwork, carb mods, or replacement, DTT ignition, 2/1 Supertrapp. Again very quick.
Scott
Old Jan 31, 2010 | 07:48 AM
grbrown's Avatar
grbrown
Ironman57 needs a Hillsidecycle on his doorstep!
Super Cycles are S&S specialists and sound a good starting place
Old Feb 1, 2010 | 04:36 AM
Ironman507's Avatar
Ironman507
Stage II
Hi Graham/Scott, thanks for the quick replies.
I've found reputable H-D tuner/engine builder (R and R cycles), albeit on the other side of the country (Queensland). I think I'll get all the cosmetic stuff done during the first 6 months and then go for the big-bore/mild cams/gas flowing along with remapping towards the end of the year, once I've amassed tons of advice from those in the the know!
Not too much in the way of snow here in Perth Graham, I'm more concerned about getting boiled alive in leathers (bikers in shorts and flip-flops are a common sight here, unfortunately)
I'll check out the Sportster forum.
Old Feb 1, 2010 | 07:51 AM
grbrown's Avatar
grbrown
Thumbs up
I was in the other Perth earlier this year and there was plenty of snow! We have family who live not far away and they were snowed in from 22nd Dec until 12th Jan!
Best of luck with the bike.
Jay1611
Jul 16, 2014 03:44 AM
lock_stock85
Sep 19, 2012 06:56 AM
shrtchngd
Engine Mechanical Topics
Jun 20, 2012 04:18 PM
spalmer1214
Apr 13, 2012 02:11 PM
04yfz450nj
Mar 14, 2009 09:28 AM
