96" specification questions
Old Mar 25, 2010 | 08:54 AM
djl's Avatar
djl
Originally Posted by Hillsidecycle.com
That is a critical dimension when manufacturing/modifiying blank-top pistons for applications that require that to be done.Scott
Thanks but I get that, just wasn't thinking out of the conventional build box. That dimension is not one most of us shade tree hacks would need.
Old Mar 25, 2010 | 08:56 AM
djl's Avatar
djl
Originally Posted by happyfeet
Thanks for the info. I was looking for that also. Trying to understand how much a .030 gasket would change the compression ratio. Also trying to figure out if I could still use stock pushrods if I used the thinner gasket.
All things being equal, the .030" head gasket will net you about a .3 point bump on CR. Another thing to consider when calculating stack height to determine pushrod length is cam base circle; they are not all the same.
nottaway
Engine Mechanical Topics
22
Oct 4, 2015 12:46 AM
steve303sg
Sep 1, 2013 02:18 AM
northeastconfederate
14
Jul 14, 2011 06:54 AM
cjlandry
Jun 5, 2011 07:10 PM
grippper
Jul 5, 2008 10:15 AM
