The Fueling tool works good and is very quick.
We made 2 more here after seeing the first.
Using a 1" travel dial indicator attatched to a plate, bolted to the cam cover screw holes works just as well, and is not as spooky as some are leading you to believe.
Scott
Thanks for all the info...
If the cam side is in tolerence (??) Do I need to check the primary side? Will the Fueling tool do the primary side?
What I mean to say was that if I measure the cam side and by some miracle I am within tolerence, should I check the primary side as well. B/C if I do have to check the primary side i'm not gonna buy the fueling tool i'll just buy a plain dial indicator.
OK, I understand; I thought you were indicating that you had checked the cam side and it was OK. Wouldn't hurt to check the primary side just to be thorough and sure but if the cam side is within tolerance, it is unlikely that the primary side is far off the cam side.
It;s been a while since I thought about engine upgrades so
How do I get to 107 from an 88?
What are the available configurations 95,103,107,110etc
thanks
From 88 to 107"??
We bore the cases to accept Axtell's 4 1/8" cylinder kit. 107".
Add a 4 3/8" crank to that and you have a 117".
Both of those powerplants work well, set up correctly.
Scott
thanks
Many great options to choose from, 95 or 98" stage 4 or 5, 103 or 107" stroker, and all of these with your stock cylinders. Very reliable as is the 117 Scott mentioned.
