F**k. Supertrap 2-1 Discretention screw snapped
Old Jun 3, 2010 | 03:44 PM
Renback's Avatar
Renback
Default F**k. Supertrap 2-1 Discretention screw snapped
Ok.
When I tried to remove som discs in order to pass the dB test I accidentally snapped one of the six retentionsscrews on my SE 2-1 supertrapp system.
I can not get hold of the end of it because it´s level with the plate holding it.
Is there a way of removing the core in this system? Bromstick and punch it out from the front end or likwise?
If I intend to drill it out and retread it I will have a loose piece of it ratteling about in the slip on, and I wouldn´t like that..
Please advice.
All the best
Tobbe
FatBoy 2006
Old Jun 3, 2010 | 05:22 PM
paul s's Avatar
paul s
On mine there is 2 screws on the bottom holding the core in.
Old Jun 4, 2010 | 03:40 AM
Renback's Avatar
Renback
Good. I´ll check. Hopfully I have the same.
Thanks.
T
Old Jun 20, 2010 | 02:38 PM
Renback's Avatar
Renback
Update:
Got the muffler out. 2 screws holding it on my SE Supertrapp 2-1.
Easy job. Bromstickhandle and a few light taps got it all out. Snapped screws accessible.
Old Jun 20, 2010 | 03:30 PM
qtrracer's Avatar
qtrracer
Smile
Use never seize when re-installing disc retention screws, but you already knew that!
Old Jun 20, 2010 | 03:33 PM
Renback's Avatar
Renback
Yes. The reason for my mishap was that I used long screws (15-30 discs) with only 3 disc to pass the yearly soundtest. Bent the screws against isolation, -made them snap.
I use Cu-past in large amounts.
Thankyou anyhow for the advice.
bagdaddy09
Jul 7, 2011 09:10 AM
Plow64
Nov 23, 2010 09:21 PM
johnltex
Aug 16, 2010 08:39 PM
whoop72
Nov 7, 2007 07:35 AM
