stripped threads
Old Jun 26, 2010 | 06:36 PM
WRAITH's Avatar
WRAITH
Default stripped threads
Does anyone know of an easy way to remove an exhaust stud, from the rear cylinder.
Old Jun 26, 2010 | 07:31 PM
cuda67bnl's Avatar
cuda67bnl
Visegrips, if you can get a hold of it.........
Old Jun 26, 2010 | 09:51 PM
ajayrk's Avatar
ajayrk
That stud is in there with and interference fit. The best solution is to drill it out with tool jig designed to guide the drill.
$60 from Georges Garage. P/N 340070
http://www.georges-garage.com/tc_engine_2.htm
I just did this on a sportster head free handed. The secrete is to be in the very center of the stud and drill all the way through the stud with a 1/4" drill and then peel out the thread shell that is left. Chase the threads with a tap.
Some one had already tried to drill it out and the hole was not on center. I had to use a dremel to carve out a starter hole that would be centered. The stud becomes hard with heat cycles and a flatter drill point cuts better in hard metal
wam6187
Nov 1, 2016 06:41 PM
72 Ironhead XLH
General Topics/Tech Tips
Aug 31, 2008 10:59 AM
roxnatwist
Feb 19, 2008 07:06 PM
Scout
Aug 19, 2007 07:40 PM
02Sporty1200C
Mar 25, 2006 10:15 AM
