Oil Leak?
Old Jul 20, 2010 | 09:39 AM
ascher08's Avatar
ascher08
6th Gear
Default Oil Leak?
I have a 2006 Electra Glide Standard with Stage 1 kit and Powercommander III. The bike also has Rush true dual head pipes and screaming eagle slip on mufflers. Other than that the engine is stock. On a couple of occasions I have noticed a little bit of oil leaking/spraying out of the engine onto the round top mounts for the air cleaner where it connects to the heads. I have noticed that this happens when it is extreamly hot and or humid outiside. The engine oil level is ok and the engine sounds normal. What could be the cause and what is the fix?
Old Jul 20, 2010 | 09:51 AM
Old Gunny's Avatar
Old Gunny
If this were mine I would take a wrench and gently see how the bolts all around there are. The vent bolts, they are hollow so be careful, just a little wriest action here , and the top covers arount there.
May be all needed.
Old Jul 20, 2010 | 01:33 PM
ascher08's Avatar
ascher08
6th Gear
Thanks. I will have to give that a try
Luca Manni
General Topics/Tech Tips
Jul 13, 2015 01:25 AM
cmosentine
Nov 6, 2012 02:21 PM
fiddledicksr
Jul 22, 2009 04:58 PM
fiddledicksr
Oil Archive (no new posts)
Jul 20, 2009 09:21 PM
HDF Tech
Sep 8, 2008 01:30 PM
