Stripped
Old Aug 27, 2010 | 09:12 PM
jndlpr's Avatar
jndlpr
Stage III
Default Stripped
Replacing rear exhaust gasket and the bolt seems to be stripped as I am trying to put it back together. Any idea how to fix my problem. Not aware of any way to fix a stripped bolt but would appriciate any feedback. Thanks
Old Aug 28, 2010 | 05:48 AM
ghanu's Avatar
ghanu
I have never done it but you need to back out the stud with vise grips or similar and replace it.
Old Aug 28, 2010 | 08:32 AM
street racer's Avatar
street racer
You said the bolt is stripped,I take it then your running a shovel head.Twin cams and Evos run two exhaust studs per exhaust port.then they connect to the cylinder heads using flanges on the exhaust pipes,bolted down with two nuts per port.If its a rear head you may be able to tap it to the next size larger.Front head most likely will have to remove it from the engine(frames in the way).You may also be able to use a heli coil or a insert as a fix.If you dont have a machinist background you might want to leave the repair to someone who dose.Break a tap off and you have a whole new can of worms to play with.
jeffjackman
2014-2024 Touring Models
17
Aug 2, 2018 07:17 AM
E-Cigrettman
Shovelhead
15
Sep 9, 2016 07:51 AM
MaxShovel
Shovelhead
20
Jun 30, 2013 09:07 PM
atretes1
Dec 6, 2011 01:27 PM
nasoscia
Shovelhead
Jul 28, 2009 01:21 PM
