Driving me crazy
Old Oct 3, 2006 | 12:56 PM
winpitt's Avatar
winpitt
Default Driving me crazy
OK, I've searched and read through the forum(s) to try and figure this out, but am now totally frustrated so I'd appreciate some help. Have a '92 Heritage with a stock 80" that I'm replacing heads, etc over the winter. A couple weeks ago it started blowing oil out the right side of the engine "somewhere". It seemed as though oil was blowing out the oil fill cap as well as possibly the breather. Checked more carefully as well as had a tech from a dealership look at it, and it seemed as though the rear rocker was leaking. Replaced the gaskets with all new gaskets. All seemed well after that.
Today the d&*m thing started doing it again. I'm at work and can't rip it apart until later this week. However, unless the rocker or head was warped, there's no way it should be the rocker. It's possible that prior to the leak starting, the bike was overfilled with oil a little. It's certainly not overfilled now. An oil change was done at the same time the rocker gaskets were changed.
Prior to a couple weeks ago the bike didn't leak a drop of oil (though it does leak a drop or two of primary oil).
A dealer tech mentioned that I could also change to the newer head vs crankcase breather design.
Anybody have any ideas? I'd sure appreciate some help! This is making me nuts.
Old Oct 3, 2006 | 01:19 PM
sleepneagle's Avatar
sleepneagle
Default RE: Driving me crazy
make sure you don't have a blockage in the oil return from the head and oil return from engine to oil tank.
Old Oct 3, 2006 | 01:49 PM
winpitt's Avatar
winpitt
Oil return and not breather? I'd think that I wouldn't have oil recirculating if that were the case. Also, another symptom:
Seems like even at idle there is more pressure in the oil tank than there ought to be. Maybe not - just seems high to me.
TerryFXST
EVO
119
Jul 26, 2019 09:37 PM
NicholasJ234
Oct 2, 2012 05:54 AM
Scudda
EVO
Jul 7, 2012 11:21 AM
punkmxcn
Aug 23, 2011 10:11 PM
Monkeyleg
Jul 2, 2011 06:57 PM
