Will not fit. The 120r is for 07 up Touring and Softails and 06 up Dynas. Different primaries, compensators, etc. The 120r fits 6 speed bikes.
Might fit if you also change inner and out primaries, clutch, transmission, compensator, primary chain, starter, etc. 2005... may have to change voltage regulator and stator too. Then... with all of that, I'm not sure if the wheel would line up with the output pulley from the transmission.....
In other words, build what I got or are there other engine options available?
S&S is our choice here, and makes most others look like there running in reverse.
From a 107" to the formidable 124"s.
And yes, those can be modified yet, in particularly via cylinder head work, to establish great reliable gains.
Scott
