TC 88 Heads
Old Jun 19, 2011 | 11:00 PM
jim70's Avatar
jim70
Default TC 88 Heads
Are there any significant changes to the 2006 and later TC88 heads as compared to the 99-05 type.
I knoe the intake flange gaskets are different but what changes did Harley make?
Which may be the better head?
Thx all
J
Old Jun 20, 2011 | 03:51 PM
KumaRide's Avatar
KumaRide
06+ heads = Larger exhaust port, better seals, beehive springs, accept higher lift cams, better flow characteristics.
Old Jun 20, 2011 | 06:22 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Thx all
J
The 06-up casting has a raised intake floor, and the exhaust ports are opened to help up the hp, and dump heat, vs the earlier head that the Moco used to specifically hold heat in, with it constricted exhaust port, in an attempt to sqeeeeeeeak past EPA emission requirements.
Once the 6-speed came, the testing being done in high gear as always, and with less engine rpms, bingo, all was well, so they cut the exhaust loose via larger port.
Scott
Old Jun 21, 2011 | 02:14 AM
jim70's Avatar
jim70
This is why I truly enjoy this forum..lots of good knowledge out there and truly appreciated.
Basically I had a big bore 95 upgrade on my 2003 Road King with 25K miles....I had some criticism about doing only the heads and not the cams but I chose bore only.
A little while back I aquired a 'take off' set of 2006 heads which I chose to install since my top end was apart...The heads fit fine with only the correct intake flange gskt requirement.
Bike runs great thus far but still in break-in period before any tuning or dyno.
I have only a free breathing air filter and true Rinehart duals.
The work was all done by a reputable shop.
Seems that the 2006 heads will be fine based on the responses and opinions.
Any other recommendations from this point forward?
Again,many thanks!
J
Old Jun 21, 2011 | 05:20 AM
Hillsidecycle.com
Sponsor
Again,many thanks!
J
Install an Andrews 26??
Scott
Old Jun 21, 2011 | 06:12 AM
bsj04's Avatar
bsj04
What is the max lift they can take assuming stock rocker arms. Just wondering, I haven't seen any numbers.
Old Jun 22, 2011 | 12:15 AM
jim70's Avatar
jim70
What Andrews 26 part numbers am I looking for?
What else to go along with the cams?
Thx
Old Jun 22, 2011 | 12:36 AM
jackstrr's Avatar
jackstrr
good imformation. THANKS I guess I will have to look for a newer set of heads. To play with in the future.
Old Jun 22, 2011 | 05:30 AM
Hillsidecycle.com
Sponsor
06-up will handle .575" lift.
Scott
Old Jun 22, 2011 | 08:43 AM
KumaRide's Avatar
KumaRide
Thx
If you go with 26's, look into decking the heads also. If funds allow, consider SE hydraulic tensioner upgrade. Although with 25k miles on an 03, the roi may not be worth it imo.
