Yep, I'd check the compensator nut. My bud's came loose last week in the middle of Utah. I made quite a racket. We managed to find some red locktite. No one had an 1 1/2" socket but we borrowed a pipe wrench from a handy man at a motel and we were good to go. Yeah he'll fix it right now that he's home.
Shave .030" off the end before intalling again with a dot or two of red loctite. Sometimes, due to machining and fitment tolerances, you can achieve the specified torque on the compensator but not achieve the clamping pressure required to keep the nut from coming loose. The .030" off the end will solve that problem.
No, don't grind the end off with a bench grinder. Take it to a machine shop so the .030" cut is even all the way round.
OK, compensator seem OK, don't have a wrench big enough to check torque, but nothing wrong to the eye. Spoke w/ a mechanic friend ( not motorcycles) he was thinking that being cranked over and hard on the gas for an "extended" period may have caused the dry sump to not have oil supplied to it?? I do run the oil a bit lower than HD recommends, about 2.5qts, but the oil light has never come on other than at first start up when cold and I'm pretty sure others here are doing the same to prevent sumping issues. So I changed the oil and added the full 3 qts that HD recommends and now the noise isn't as loud but it's still there. It has to be something in the top end, I swear that's where the sound is coming from. It's also definitely running on both cylinders, not just one and it didn't seem do be an overly rough idle. I only ran it for 20 seconds or so.
The compensator won't appear loose but it will tighten up if you try. I believe it takes an 1-1/2" socket. It may not be the compensator that's making the noise but it's worth checking, they come loose frequently and scare the hell out of a lot of guys. I know a guy who had one come loose back in '05 and thought the motor was coming apart. He sold the bike cheap. The new owner, I know him too, tightened up the nut and is still riding that bike!
When my comp nut came loose it also appeared to be tight then I put a big wrench on it and it turned with little effort.removed cleaned loctite reinstsalled all is good. Just saying give a good wrench on it before thinking its not loose
