Oil pressure
Old Nov 21, 2006 | 02:18 PM
jjb's Avatar
jjb
6th Gear
Default Oil pressure
Will an increase in oil pressure help or hurt a stock twincam 88?
Old Nov 21, 2006 | 02:26 PM
sleepneagle's Avatar
sleepneagle
Default RE: Oil pressure
there are higher presure pumps and/or pressure springs that raise the oil presure. HD is a dry sump systems where oil is pumped and siphoned back out of the case. It's not so much the pressure but the amount of oil flowing. The reason you see the pressure gauge drop at idle is not because there is less oil being pumped. The volume is still there.
Old Nov 21, 2006 | 05:02 PM
dawg's Avatar
dawg
What is your oil pressure at normally? If it is 32+ or so when running it will be fine. Like posted above it does drop when idleing and you can get a Zipper shim or Baisley Spring.
FL-kruzen
Jul 13, 2013 10:30 AM
scaley
Oil Archive (no new posts)
Sep 20, 2012 04:55 AM
Klor
Jun 4, 2010 10:55 AM
jseabee
Jan 7, 2008 06:13 PM
jjb
Nov 21, 2006 02:22 PM
