HSR42 runs real bad with TC88 need help
Old Nov 26, 2006 | 08:43 PM
stereophile33's Avatar
stereophile33
Stage II
Default HSR42 runs real bad with TC88 need help
Had Tripps Harley Davidson install a HSR42 and hypercharger on my 2000 Low Rider that has some V&H big radius pipes.
They said they got it all adjusted, but the bike barely idles and it spits when I start in on the accelleration.
I have read through the tuning manual 5+ times and have done all that I can. Without a 5 gas analyzer it sure is hard to tune these suckers.
Anybody have any tips?
Jonathan
Old Nov 26, 2006 | 08:48 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: HSR42 runs real bad with TC88 need help
first get rid of the Hypercharger. The HSR's should be able to be dialed in. Is there any more to the combination?
Old Nov 26, 2006 | 09:03 PM
stereophile33
Stage II
that is actually it, nothing else has eevr been done to the bike.
I seem to be unable to find a place around that has a dyno to try and set-up the carbs...
Old Nov 26, 2006 | 11:52 PM
murphdog's Avatar
murphdog
What jets, needle, needle clip position, accel pump nozzle, accel pump adjustment, idle mixture screw setting do you have? Is the enrichener working properly per the tuning manual; proper amount of free play? Is the carburetor seated properly in the manifold seal? Sometimes you have to file the cylinder fins down a little to allow the carburetor to fully seat. If it's not seated, you likely have a vacuum leak which would explain your symptoms. Also, the throttle/idle cables must be rerouted to either the left side of or below the frame backbone under the tank to allow the carburetor to seat in the manifold seal. The tuning manual is actually quite good in that it tells you how to troubleshoot and tune each variable. You should be able to get it dialed in very close without a dyno.
Have you considered taking it back to the installing dealer and complaining? If you don't want to do this, consider pulling the carburetor off and checking everything per the installation and tuning manuals. The bike should run good with the carb set up as built, but will probably be a little rich on the pilot jet. It must be installed properly, however.
Chopster1200
Oct 27, 2009 02:12 PM
csd4682
Ironhead
May 24, 2008 11:12 AM
debo
Mar 3, 2008 12:13 PM
Sally88
Jul 31, 2006 04:00 PM
