do i need to dyno tune
Old Dec 15, 2006 | 12:18 AM
high side's Avatar
high side
2nd Gear
Default do i need to dyno tune
if i was to install slip ons instead of a full exhaust,would i still need to flash my chip??? and dyno tune?? I have a 06 road glide
Old Dec 15, 2006 | 08:52 AM
dawg's Avatar
dawg
Default RE: do i need to dyno tune
Just slip ons, no. But a dyno wouldn't hurt it.
Old Dec 17, 2006 | 02:17 AM
Hogaholic's Avatar
Hogaholic
If its an o7 you need a flash or pc111 right out of the door. If you do anything to the motor at all you are rolling the dice on engine damage without a programmer.
Old Dec 17, 2006 | 02:32 AM
Shovelhead Bob's Avatar
Shovelhead Bob
It would be to your advantage to get an ECM update or an EFI Management unit (SERF/DFO).....
If all you are doing is putting on a set of mufflers, you need to remember that you will be taking away backpressure, as the stock mufflers on 06's had a catalytic converter on the right side.......
Take that away, and you lose a little bit of scavenging....
If you are planning on installing an AC unit, you MUST upgrade/Update the ECM programming........ More air means you need more fuel for optimum performance......
09IronRider
Milwaukee Eight (M8)
Sep 24, 2018 01:52 PM
JBrock
Dec 8, 2017 11:32 AM
gb911
Jan 26, 2012 04:22 PM
Westy
Jun 23, 2010 08:24 PM
HD101st
Apr 16, 2010 08:10 PM
