I have a 03 fatboy with v&h big shot staggered pipes Ness big sucker and a power commander.I want to put new cams in it.Is se203 or se204 my best choice?. I don't want to do any head work and don't want to install bb kit. what would be best choice of these two? what is performance differance between these two ?.
Either would be a good choice. The SE203 is more of a bottom end cam and meant more for baggers while the SE204 is more of a mid range cam and meant more for the ligher softails. Without knowing how you ride, difficult to say which would be a better fit but I am guessng that you would prefer the SE204 over the SE203.
Two other cams you might consider are Andrews products; TW21 and TW26. Similar to SE203 and 204; the 21 is more of a bagger cam and the 26 more of a softail cam.
It would be a good idea to change cam chain tensioners and inner cam bearings and add the Baisley LMR-002 pressure relief spring as part of the cam upgrade.
mwsanford I would recommend you do some searches on this site regarding cam selection. You do not mention your riding style (I live for the top end, or I want power off the line, or I need more pull up the hills) or your size, or if you ride two up a lot.
I don't have all the answers but can comment on my Andrews 21 cam set up. Now I have a Road King and the A motor if that matters. But I am a big guy and ride 2 up about 25% of the time. I wanted power, and lots of it down low in the RPM range. Right where most Harley riders ride on an everyday basis.
I did a lot of research for cams for an 88" motor (different than the 96 or 103s) and this one seemed the best for me. Well let me tell you I am more than pleased with the performance of this cam. Totally woke up my motor. Fast off the line, pulls like a tractor up hills, and kept all or more of the performance on the top end compared to the stock cam. For everyday riding/touring you would love this cam.
