night rod blow head gasket twice
Old Jun 19, 2012 | 12:06 AM
stevemaman's Avatar
stevemaman
Default night rod blow head gasket twice
hello to all . my night rod special and this has turned to a nightmare ! need some tech help.
had low coolant ,mechanic filled up.
head gasket blew 2 miles later and compression was being heard from the front head.
had a new one installed. all fluids done again.
50 miles later, noticed that i was losing coolant again thrrough the side of the water pump cover where there is a little opening .
we changed all the gaskets for the water pump.
the leaking stoped there and there was coolant coming out of the side bolt covers...
then again, the head gasket blew and again losing compression and collant through the gasket and exhaust !
any ideas why collant comes out from the casing bolts under the water pump ? why it blows head gaskets ? the fan works fine. it never overheated on the gage...
Old Jun 19, 2012 | 07:55 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Surfaces not flat?
Torqued incorrectly?
Scott
Old Jun 19, 2012 | 09:10 PM
sicpup's Avatar
sicpup
low coolant why? was the coolant system pressure tested? plugs bleach white? oil have water it? milky color oil or under dipstick cap?
did gasket blow/torch? head lift? fasteners torque to yeild?
right.. weep hole for the waterpump shaft/gasket
not sure here.. bolts penetrate water jacket? thread sealant used?
and exhaust?? is it smoking blue/grey out exaust?
dude, way more info is needed.. a mechanic needs to make sure everthing is mechanically correct.. dimenisionally.. fasteners torwued to spec.. correct sealants/gaskets.. timing is spot on.. static compresion is adequate.. compression ratio isnt through the roof.. nothing warped.. etc etc.. chasing gremilins till then.. hell overheating will cause the radiator to **** coolant everywhere.. but it takes a lot to kill/warp head.
you need to know the history of the bike or comb through it w a fine tooth comb..
been where you are and it aint fun
leafman60
Feb 15, 2020 12:27 PM
SCHOONER
Feb 1, 2013 02:54 PM
Qckfr
Mar 29, 2009 02:42 AM
