Quick connect checkvalve leaking, need upper o-ring
I have a 2006 wide glide with a leaking upper o-ring on the inside of the quick connect under the tank. I have the lower o-ring but cannot find the part# or specs for the inside upper o-ring and mine is in about 30 pieces. I think that all of the bikes with quick connector checkvalves use the same o-rings. HD wont sell just the o-ring they want to sell the whole valve and fuel line assembly. Just to be clear I do not need the large o-ring that goes between the checkvalve and tank but the upper o-ring inside the checkvalve that keeps the valve sealed when no hose is connected. I would appreciate any help as I am unable to ride and unwilling to spend $65 because I have a bad $1 o-ring.
I'm not sure what o-ring you need but this is the one most likely to fail.
Harley fuel tank o-ring in the female section.
Harley # 11273 or John Deer # R26286. (10mm id x 14mm od)
Harley drain plug o-ring # 11105.
http://partsfinder.onlinemicrofiche....-TANK-ASSEMBLY
Similar issue with my 05 Ultra. Bike just shut off one day. O-rings were swollen, dry and cracked. Inside the check valve, the large o-ring is m2 x 10. the smaller one (shut my fuel off) is m2.4 x 8.3 . The one in the fuel line is m2 x 5. I suggest you try to find viton o-rings. Nitrile rings will probably be OK. DO NOT use rubber o-rings available at most hardware stores. The modern gas will just eat them up. You can buy viton o-rings from Amazon 25 at a time. Share the extras with your friends. Hope this helped.
Skyking75
15
12-11-2018 03:05 PM
beemer737
Exhaust System Topics
08-25-2010 05:53 PM
