too lean???
Old Jan 20, 2007 | 12:19 PM
dannou's Avatar
dannou
Stage II
Default too lean???
Guys,
I'm doing a "hop-up" job on my 2000 Springer which was already at Stage 1 with "free-flow" everything. I'm really in need of some "experienced tuner/wrench help". I'll list what it had before my hop-up project:
[ol][*]Screamin Eagle "free-flow" intake (K&N Filter, thunderslide, dynojet)[*]Keihin CV40 carb[*]Straight TC88 Engine
[*]D&D Slip on balogny cuts.[/ol]
This
ran great for years, so I figured (ha,ha) I'd try to get something outta the TC88, the "hop-up" included the following additions.............
[ol][*]Same as above plus............[*]Screamin Eagle Performance heads[*]Cometics .030" head gaskets
[*]Daytona Twin Tec TC88 ignition (mappable)
[*]Andrews TW37 cams[*]Magnecor wires and coil[*]Basically ALL new electronics minus regulator
[/ol]
Got everything bolted on per all manufacturers documentation, turns over "just nice". You can hear that something wants out!!
My problem, I'm having a hard time starting it, actually it ran on one cylinder at first, and once I get the thing started, I've really got to "stay on it" to keep her running. I adjusted the mixture needle out to make it richer, the further I got the easier it seemed to start. Still had to play with the throttle to keep her going. Does this sound like the normal condition before I get it "dialed-in"?
Should I try to rejet the Keihin, and work with the timing. It sounds LEAN to me.
Thanx for everybody's input ahead of time,
DannoU
p.s.
I'm up in Michigan dealing with temps. in the teens. Doing it in the garage, alone and having a "helluvalottafun" doing it too. BUT HELP is needed!! THANX AGAIN!!!
Old Jan 20, 2007 | 12:55 PM
DJJSR's Avatar
DJJSR
Default RE: too lean???
With your cam and head change, I think a re-jet is in order. HOWEVER, you say the temp is in the teens and unless you plan on riding in that kind of temperature, don't bother with re-jetting yet. If you get it right for that extreme cold, it will be too fat when the weather gets nice.
Old Jan 20, 2007 | 06:34 PM
1200cc's Avatar
1200cc
,,the first reply makes since to me,,i did a small re-jet
on my 1200,cc sporty,,at the temp,here in WV at 67 degrees
bike ran like a racer,,but i try it at 32,degrees things changed
got the ole-harley carb cough,,,but not once did it do it at
the warmer temp,,and ran great,,so im not going twisting no
screws just yet,,but i did not know how much temp,would
change things,,so it might be a warm weather bike,,LOL
i know im a warm weather rider,,hope you get-her in tune
cool-rider
Jul 2, 2012 05:29 PM
cool-rider
General Topics/Tech Tips
Jun 27, 2012 05:08 PM
NewHarleyGear
Motorcycles For Sale
Aug 4, 2011 04:38 PM
EvilWayz
Ironhead
Dec 9, 2009 08:02 PM
phat96
Apr 11, 2009 10:44 PM
