Drag pipe performance
Old Sep 3, 2012 | 07:43 AM
essentialcycle's Avatar
essentialcycle
Default Drag pipe performance
I have a 1995 dyna superglide with 2" drag pipes, an andrews EV27 cam and ness big sucker air filter. No other upgrades. I am wondering if I can get any more bottom end to mid range power back if I install some baffles in my pipes? I can't fork out the coin for new pipes. Any info would help!
Old Sep 3, 2012 | 07:47 AM
Stiggy's Avatar
Stiggy
Yes, but the sound will change drastically. You won't like it.
You can drill a bolt hole through the back of the pipes and insert stacked washers. Or you can buy "Lollipops" which accomplish the same thing with better results.
Old Sep 3, 2012 | 07:53 AM
grbrown's Avatar
grbrown
I really don't think there is much you can do with drag pipes. They are essentially tuned length and work best in the higher rpm range. You would be better off IMHO keeping your eyes open for a 2-into-1 system, which will give you significantly improved low/mid range performance. Take a look in the classified ads here on HDF and Ebay, to see if something affordable and secondhand comes up?
Old Sep 3, 2012 | 08:17 AM
essentialcycle
Just did a little research online. Lollipops are inexpensive and have the potential to increase power without sacrificing alot of cash. Very cheap to make! If it doesn't seem to make enough difference for me, then I guess it's E-bay time.
Old Sep 3, 2012 | 08:26 AM
mrlexus's Avatar
mrlexus
Watch
If you still have the stock exhaust with he crossover, put that back on with some gutted slipons, it will still be very loud but get you some power back.
Old Sep 3, 2012 | 08:57 AM
prodrag1320's Avatar
prodrag1320
get rid of the pipes!!
Old Sep 3, 2012 | 11:01 AM
grbrown's Avatar
grbrown
Wink
I think what Prodrag is telling you is don't waste even a cent on your current pipes!
Old Sep 3, 2012 | 01:28 PM
blue flht's Avatar
blue flht
I have a 86 evo with the EV27 cam in it, I would get rid of the 2" drag pipes. Just to big for what you have.
Old Sep 3, 2012 | 05:36 PM
essentialcycle
Well, it seems that the drag pipes really are not for my application then. I love the sound, but I hate not having the performance. After riding it for a couple years and going on long trips, I think it's time to change them out. Can I get performance out of the stock headpipes and long pipes with baffles? I like the V&H Longshots, but cant afford them. They don't go for cheap on e-bay either. I keep an eye on craigslist, but no prevail. If I use my stock headpipes, I want to cut out and weld up the cross over pipe. Would this set-up work? I would use steel baffles with no packing. Just trying to save some cash. Owning a home aint cheap!
Old Sep 3, 2012 | 05:50 PM
blue flht's Avatar
blue flht
Yes it would, but if you are set on drag pipes go to a smaller size pipe and use baffles.
