cam fitment
Old Dec 20, 2012 | 09:16 PM
bigdog1949's Avatar
bigdog1949
Default cam fitment
i have an 02 flh 88 stock,need to know if 04 softtail cams are the same as my 02 flh
Old Dec 20, 2012 | 10:44 PM
pjchamp's Avatar
pjchamp
they should be, i believe 06 dyna's and up and 07 and up on other models they changed the cam plate
Old Dec 21, 2012 | 08:51 AM
No Name Motorcycle Shop's Avatar
I do not have the correct parts book to check the 04 Soft but as long as your bike is a carb model it looks to be the same camshafts. If your bike is injected it would have used different camshafts.
Old Dec 21, 2012 | 11:38 AM
djl's Avatar
djl
The cams for the early carbed bikes in the "A" engines have an intake close of 38* while the early EFI bikes with "B" engines (softails) have an intake close of 34*. So, you can use either just be aware that CCP will be a bit higher with the 34* intake close, which won't hurt anything and would help low end torque a bit.
mjpeterson777@gmail.com
Shovelhead
63
Aug 2, 2016 12:09 PM
CtCruzer
Oct 15, 2011 11:30 AM
akroguy
Jun 13, 2010 10:34 AM
shadylane
Apr 9, 2010 03:17 PM
Timboto
Shovelhead
Sep 30, 2007 09:33 AM
