CAMS and HEADWORK MATCH?
Are those #'s for a specific cam?
Anyway, I digress. Flow at .600" lift means nothing, that is just what the heads are capable of flowing at that lift. Without knowing what the head flows at the lower lifts; you don't know anything. I also noticed that FLRH2000 didn't say whether those readings were at 10, 25 or 28 inches of water column. Don't get hung up on flow numbers; Bean doesn't provide flow numbers but many head porters do. That data only shows what those heads flowed on that head porters flow bench. Flow test them on another bench and I will guarantee the data will be different. Then your air filter must flow an equal amount; having heads that flow 260cfm doesn't mean much if your air filter only flows 210cfm.
Pick your cam, get your heads ported to match, get a good tune and forget about flow; it doesn't matter.
Reminds us of the "3/4 race" cams that J.C. Whitney used to sell.
Scott
A competition valve job generally implies a multi-angle valve job which can be done on a set of stock, non ported heads; it's just a trick valve job.
dano,
Those flow rates work for a LOT of them (to many to list.) 95" to 103" CID.
Don't get hung up on the cam, focus on the fact your trying to feed a CID within a specified time interval. The CID will dictate the potential TQ, the RPM range the max TQ is made will show as HP. No matter what cam you use, 95" CID is always going to be 95" CID and the exercise of filling the cylinder to it's max never changes.
>It's not that simple.<
For real, it is.
>Flow at .600" lift means nothing, that is just what the heads are capable of flowing at that lift. Without knowing what the head flows at the lower lifts; you don't know anything.<
WTF? It means EVERYTHING the ONLY thing, without in increase in flow, material removal does nothing more then lower velocity. With that said, the importance of the flow rates at the higher lifts are indicative of the MOST IMPORTANT things when it comes to heads.
1st. The heads don't stall, won't stall, and/or flow backwards at the lifts lower then .6" to include .57" .51" .5" .498" etc...
2nd. EVERYONE KNOWS you can't have 260+ CFM @ .6" and NOT have 250, 240, 200,CFM etc at the lower lifts, what do people think, the head flows absolutely nothing until .6" lift then BANG 260? Nothing in between? So if you KNOW the head flows 260+ at .6" lift you KNOW what it flows @ .5", .4", .3", .2", .1" etc....and then you KNOW what it will do when harnessed to a specific set of supporting parts.
>I also noticed that FLRH2000 didn't say whether those readings were at 10, 25 or 28 inches of water column. Don't get hung up on flow numbers<
28", 260 @ 10" Would be 430+ and unachievable N/A in a stock cast TC head.
FWIW, ABSOLUTELY get hung up on flow numbers, when it comes to head porting, in spite of what you read on the internet, NOTHING else matters.......for real.
