p0117 code
Old May 6, 2013 | 08:49 PM
rtbassmaster's Avatar
rtbassmaster
Stage I
Default p0117 code
2007 harley sportster 1200 custom what sensor is p0117 et sensor voltage low efi does not idle till warmed up run rough going down the road.
thank you
Old May 9, 2013 | 07:14 PM
target64's Avatar
target64
that code is for engine temperature, the sensor works off variable resistance. the ecm supplies 5 volts to the signal circuit and ground to low reference circuit . when engine is cold the resistance is high as engine temp increases the resistance decreases the ecm detects high temp indication it set code. so your sensor is the most likely cause its telling the ecm your temp is at normal operation or higher when its actually cold and the fuel delivery is too lean for the cold engine until it warms up. disconnect the et sensor and test for 5 volts and ground with ignition on. its at the back side of front cylinder. use a small paper clip to insert into the terminal ends don't jam the tester leads in there it will spread them out and cause problems of bad contact. it u have 5 volts and ground replace sensor.
WoodButcher66
2014-2024 Touring Models
May 31, 2021 06:08 PM
Dcampri
May 2, 2019 11:11 PM
Z
24
Nov 3, 2018 08:49 PM
txphatboy
13
May 20, 2018 09:40 PM
redrub
May 30, 2013 11:25 PM
