Rineharts installed...yellow pipe quick!
Old Feb 21, 2007 | 09:38 AM
jrudicel's Avatar
jrudicel
Default Rineharts installed...yellow pipe quick!
Installed my new Rineharts last night. Kinda a pain, especially getting to the manifold nuts. Did not do air cleaner yet, but went ahead and started it. Front cyclinder which i didnt get the heat shield on yet, turned gold in a matter of 1-3 minutes. Is this normal? Didnt figure it would be way too lean until i did the air cleaner.. Also,, I screwed up the new stock gaskets as ii was trying to push them into the heads. Did not have enough patience I guess. Anyways, I used the James gaskets that came with the Rineharts. Bad move?
Old Feb 21, 2007 | 12:20 PM
rideon's Avatar
rideon
Default RE: Rineharts installed...yellow pipe quick!
Your bike will be way to lean without some sort of fuel management device, a dyno tune would be a good investment. I used the james gaskets and had no leaks.
Old Feb 22, 2007 | 12:18 AM
jrudicel's Avatar
jrudicel
Yeah, got a dyno tune coming in a few days. I was just surprised how quick it yellowed especially since I hadnt changed the AC yet...
Old Feb 23, 2007 | 05:56 PM
MCSarge's Avatar
MCSarge
If you just changed the pipes and not the air cleaner I don't think you are running that lean. I think that because the pipe is designed to run behind a heat shield it does not have any type of hi-temp protective coating and the normal high temperatures in that area discolored the bare pipe. A friend of mine used those gaskets and never had a problem. Good luck on the rest of your mods
Lentini93
Jun 26, 2015 07:51 PM
Pastor Ron
2014-2024 Touring Models
11
Jul 25, 2014 09:21 PM
riderboy1961
May 23, 2014 04:26 AM
Platinum
Fuel Moto / Jackpot Mufflers
Apr 5, 2014 05:04 PM
papejr
Aug 20, 2012 02:12 PM
