Mikuni carb
Old Feb 21, 2007 | 08:29 PM
Tn.Heritage's Avatar
Tn.Heritage
Default Mikuni carb
What size jets are standard on the mikuni carbs, 42mm, also what size jets would you suggest if this was put on a 98 evo motor on a softail, pipes almost like drag pipes.
This is for a good freind of mine who has had problems with the stock carb since the bike was new, he put a mikuni on it and it runs 10 times smoother but seems a little lean, and doesn't quite have the pulling power it did.
Any help would be great.
Old Feb 22, 2007 | 10:07 AM
Tn.Heritage
Default RE: Mikuni carb
Man, I can not beleive that someone don't know what this is, c'mon now.
Old Feb 22, 2007 | 01:12 PM
1flhtk4me's Avatar
1flhtk4me
I would suggest doing a search on the net.
Try Sudco/Mikuni.There should be a webite for their carbs.
Old Feb 22, 2007 | 01:56 PM
RenoGlide's Avatar
RenoGlide
Heres the Mikuni web page link, start there, download the manual & read it. Lots of info there
http://www.mikuni.com/fs-carburetor.html
New Mikuni 42s come with a 25 pilot jet, 160 main & a ( I think ) -96 needle
Normally, its a decent set up to begin with
Mikunis have multiple adjustments for tuning, ... pilot & main jet sizes, needle sizes, needle position, fuel nozzle ( squirter), squirter pump adjustment, idle air screw... you get the idea
Mikunis can be a pain to get tweeked just right... but when dialed in, they will out perform almost all carbs.
Tips:
Make sure your throttle slide is opening all the way at full throttle
Replace your fuel bowl screws with allen heads, makes removing the back bowl screws much easier
Mikunis are prone to air leaks at the manifold junction
If you hear a noise .. clock, clock, clock at idle... thats slide rattle & is normal
You can replace the long black idle adjuster with one of thses ... http://www.fastaire.com/mikuni.html
Buy several sets of cheap Champ RN12YC plugs ( stock heads ) and do a plug check with new plugs
Take your time, make one small adjustment/change at a time & test ride it.
Reno
www.FastAire.com
Bubby
May 3, 2019 06:23 PM
bubdifab
May 11, 2008 09:47 AM
missin
Shovelhead
May 17, 2007 01:00 PM
Toyman
Classic
Mar 25, 2007 10:34 PM
radloser
Feb 4, 2005 09:40 PM
