Stalling at red lights ect?
Old Aug 5, 2013 | 06:01 PM
McKelveyMX's Avatar
McKelveyMX
1st Gear
Default Stalling at red lights ect?
After cruising, usually on the interstate or highway, when I come to a red light or exit and let the engine rev down, when I clutch it occasionally (becoming more frequent) the engine will just stall out. When I start it back, it run as long as I keep a little fuel pumping thru it. After it sits a little while it will start up and idle just fine. Any suggestions on what I should check?
Old Aug 6, 2013 | 03:01 PM
sweet94flstf's Avatar
sweet94flstf
I heard about this before but cant remember where anyway did you put a inline fuel filter in by chance iv heard that sometimes this will cause a vapor lock from the motor heat.
Old Aug 6, 2013 | 04:00 PM
ajayrk's Avatar
ajayrk
Is the fuel pump access plate held in by a snap ring? Those early pumps have a faulty filter cover that can leak and loose pressure.
Old Aug 7, 2013 | 06:05 AM
blackpearl's Avatar
blackpearl
try cleaning the IAC with some throttle body cleaner
Old Aug 7, 2013 | 07:32 AM
Captain Itch's Avatar
Captain Itch
Sponsor
My 07 would idle high and this was the problem..Cleaned it 3 times over a 6 month period and the problem never came back..I know that I just jinxed myself by mentioning this..
__________________
www.Captain-Itch.com
Old Aug 7, 2013 | 02:40 PM
McKelveyMX's Avatar
McKelveyMX
1st Gear
Thanks guys! I'm gonna try cleaning a few times. If that doesn't work, ill try replacing it. Would brake cleaner be safe to use to clean it, or would I need throttle body cleaner?
Old Aug 8, 2013 | 05:13 PM
blackpearl's Avatar
blackpearl
I wouldn't use brake cleaner just because its for brakes and not a throttle body
PB_Vroom
Sep 2, 2017 11:59 AM
cdavidj
Sep 1, 2015 11:06 AM
BMOTOXSTAR
24
Jul 30, 2014 11:24 PM
thunder7
Sep 26, 2012 10:59 AM
kmundy05
Jun 20, 2012 11:34 AM
