I just bought a 2014 street bob with the 103 in it. looking for a new exhaust and when I search they only have 2013 available as an option, I know that 2013 street bob had the 96 in it. im wondering if the exhaust designed for the 96 will fit the 103 or am I stuck til the 2014 option is available.
Somebody here might know for sure, but I know that the exhaust companies will not leave you out in the cold for long - I would decide which pipes you want and call the company.
Welcome to HDForum, be sure to "hang out" over in the Dyna area - tons of good info, especially using the "Search" feature.
Reason: Added on
I don't see why they would be any different. Frame didn't change and neither did the engine. There was a change between 11 and 12/13 but it was due to the smaller O2 sensors on the newer models. You should be able to use any exhaust for 12 or 13...or if u use a tuner that deletes the sensors then u can go back to 06. You would just have to put bung plugs in.
The 13 was standard with the 96, you had to Hd1 the 103 unless it just happened to be on the floor from the dealers alotment. Either way, exhaust ports are no different between the two.
