Twin cam oil puking from a/c
Old Nov 17, 2013 | 10:06 AM
micalaut's Avatar
micalaut
Default Twin cam oil puking from a/c
I know there are a lot of discussions on this topic however all situations seem to be a little different. I have a 2006 Ultra recently upgraded to 95" big bore, Andrews 26's, compression at 9:6, mild head work and baisley oil spring. It had and still does, SE air cleaner and Rinehart slip ons and a fuel tuner. I followed the break in recommended by the shop that did my boring and piston fitment. Had no problems for the first 900 or so miles. Then one day ran her pretty hard for 10 or so miles and after settling in to a 50mph cruise home she started blowing oil out the air cleaner, not a small amount, probably several ounces. I pulled over figured I blew a piston or dropped a valve through one, waited a while checked oil , then started motor to see what I had. Perfect, started right up, no noises, good power, figured I'd better get it home. Looked it up on this forum saw it was pretty normal with oil level at full. Now with the oil level down figured I was good to go. Took it out yesterday and it started again, couple ounces of oil dropped between lifter blocks. Took AC off and found filter soaked at bottom and seal distorted and torn. Could this cause too much air movement inside air cleaner? How important is the seal of the AC backing plate? I ran it in the driveway with out the air cleaner and there is no pressure coming out of head vents. Any thoughts would be appreciated.
Old Nov 17, 2013 | 01:30 PM
ml crisis's Avatar
ml crisis
Just a suggestion, had a similar issue on a 96" Rocker. The heads vent into the throttle body. If you get too much oil up in the heads it gets drawn into there and will soak everything. Long story but in my case the line that vented the sump to the oil tank was gone causing the sump to be full of oil instead of getting back to the tank. When there is too much oil in the engine piston action ends up pumping a lot of it and vapor into the heads which gets drawn into the TB.. maybe there's a problem in your oil lines somewhere...
Old Nov 18, 2013 | 08:56 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We like to enlarge the drain holes in the rocker suppports to .125", and might try venting the heads to the outside.
Scott
Old Nov 18, 2013 | 09:20 AM
ajayrk's Avatar
ajayrk
Wet sumpping, leaking oil pump seal or pump rotor damage.
Plus 1 on drilling the the return holes larger. That should be an automatic for informed shops.
Old Nov 18, 2013 | 03:50 PM
Kingofcubes's Avatar
Kingofcubes
What everyone has offered plus don't fill the oil bag full and use non-synth oil.
Old Nov 18, 2013 | 09:24 PM
micalaut's Avatar
micalaut
Thanks for all the responses, any chance it's a defective oil filter?
jeffsizemore
Mar 24, 2017 11:37 AM
macodaniel
Mar 16, 2015 05:21 PM
tripwire759
Oct 30, 2008 10:35 PM
TakeNoCrap
15
May 1, 2008 06:55 AM
HDF Tech
Engine Mechanical Topics
Jun 25, 2005 12:53 AM
