Revs
On a side note, I think the primary chain may need adjustment. I have told them to check it out three times and they have claimed that they have adjusted the chain or it doesn't need adjustment. However, when I'm creeping the bike at 7 mph it will jerk periodically. The bike will run "rough" until I put a passenger on the back and then it will smooth out.
Any input would be appreciated. Something about this bike isn't right and I'm trying to figure out the problem.
The jerking your are talking about...is the throttle at idle at this low speed? What gear are you in? It doesn't seem entirely normal, but no telling...is your throttle and idle cables properly adjusted? If it's that sluggish, you may not be getting the throttle body to open all the way due to a poor adjustment, conversely, if the idle cable is improperly set, you may not be getting a fully closed position either, though it sounds more like the former...if this is the problem at all.
I would get the manual, and start checking things over if you don't already have them. Both these adjustments I talked about are very simple procedures and you can do yourself with just a little bit of patience.
Mac
Now for the revving. The bike is idling at approx. 1K rpm right now. When I rev it up to 1200 rpm it will take approx. 2-3 sec. to return back to idle. When I rev it up to 2K rpm it will take 5-7 sec. to return back to idle. I have tried messing with the throttle lock and can't get it to drop quicker.
Great suggestions. I'm going to do what you said and update you with the results. Thanks a ton.
