Thunderheader problems
Old Mar 9, 2014 | 01:49 AM
chevypilot's Avatar
chevypilot
Default Thunderheader problems
Hello, having a few issues here. Any thoughts are much appreciated.
I have a 2013 Road glide. 103ci with woods tw555 cams, cobra fi2000 powerpro auto tuner, v& h powerpro high output 2-1 slipon, SE stage1 air cleaner with k&n hiflo filter, and stage2 flash.
This setup was working perfectly, but I had to have a 2-1 thunderheader. I bought and installed it with new exhaust gaskets. No heatshields.
Now the pipes and exhaust run super hot and at 3500rpm it stumbles. If I quickly roll through it, its unnoticeable, but if I sit at 3500 its coughing. Any gear. No other symptoms.
Do I need to dump the cobra and get a super tuner with dyno or thundermax? Do I need another flash? I'm just pissed I have to take it back off now till I can afford that stuff. I thought my cobra would handle it.
Old Mar 9, 2014 | 06:04 AM
target64's Avatar
target64
need another fuel map if its available for that tuner sound lean. or power vision, or a tuner with auto tune set up correctly will solve your problem.
Old Mar 9, 2014 | 06:58 AM
checkers's Avatar
checkers
Both symptoms indicate a lean condition. The Cobra tuner is an auto tuner, and should compensate. I would look at a smaller baffle size or an exhaust backpressure baffle or lolli-pop back pressure modification.
marcus9x9
45
Nov 21, 2017 10:52 AM
jyoder4241
The Dyno Room
Apr 27, 2016 09:40 AM
Techgnosis
Jan 26, 2014 04:25 PM
paracon
Feb 21, 2010 02:57 PM
TedMan
Jul 13, 2009 11:58 AM
