idle mixture screw
Old Apr 2, 2007 | 12:22 AM
chrism84's Avatar
chrism84
Default idle mixture screw
ok so lets say that the carb has never been ****ed with and the idle mixture was not drilled out....what is the setting of the idle mixture usually...all the way closed or what?? i accidently removed it thinking it was a jet and now am not sure what setting to put it at.....so what would be the best way to set it before i start the bike up again....i have just done the 1200 conversion and when iget my stuff back i want everything to go well
Old Apr 2, 2007 | 10:29 AM
twowheelsforever's Avatar
twowheelsforever
Default RE: idle mixture screw
Anywhere around 2 to 2-1/2 turns out from all the way in should be close enough to get you started.
Old Apr 4, 2007 | 07:36 PM
Booey424's Avatar
Booey424
i heard the same.2-2.5 turns from closed is where you should start
[IMG]local://upfiles/25674/D2A8DE6F500F4C82BBD8150320E324EC.jpg[/IMG]
unregistered436
May 27, 2014 12:29 PM
Nuday
May 3, 2013 07:24 PM
XL1250
Jul 21, 2012 06:17 AM
hddee
Shovelhead
Jul 27, 2008 12:05 AM
redrum
May 31, 2008 12:19 AM
