Cam Timing?
Old Apr 4, 2007 | 07:05 PM
Viejo's Avatar
Viejo
Default Cam Timing?
Working on a poor fuel consumption. My assumption at this point is that the SERT has been tuned properly. (se slip on’s, air filter). I have a lot of engine noise 2800 to 3000 RPM when accelerating. Could this be a loose cam chain and would that change the cam timing and would that cause poor fuel economy? Wow that’s a lot of questions. Any help would really be appreciated. Bike has 5000 miles and 28 mpg.
Viejo
Old Apr 4, 2007 | 07:30 PM
Sleeps In Trees's Avatar
Sleeps In Trees
Default RE: Cam Timing?
What's that old saying about assumptions? Sounds likea tuning problem to me; poor feul economy & pinging under load. Did you get a print-out of the sert tune? If so did the AFR look ok?
VicW.
Old Apr 5, 2007 | 09:45 AM
Viejo's Avatar
Viejo
Thanks for the reply. The noise is not a pinging but rather a rattle type, metallic sound. Lessens with higher or lower rpm. The AFR printout is right on 14ish. Heavy fuel smell and very rich exhaust. The standard MAP was installed for bike setup.
Old Apr 5, 2007 | 02:41 PM
mtnlvr's Avatar
mtnlvr
What part of the engine is it coming from? Upper? Lower? Mid? Maybe the tranny?
Old Apr 5, 2007 | 08:41 PM
Sleeps In Trees
Did the engine just recently develop the rattley noises? '14ish' AFR & 28 mpg, something sure as heck ain't right there. How's your plugs look? Have you talked to the shop that did the work?
VicW.
Stickman53
May 29, 2014 09:05 AM
skjskmata
Sep 19, 2011 09:03 PM
trook
Sep 26, 2010 11:24 AM
JockWhisky
Mar 18, 2009 10:31 PM
jsbridgew
May 16, 2008 10:08 AM
